SOURCE: Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
SOURCE: Canon IR 210S "Close the Lower Right Door" warning
Yes there is a sensor that most likely got knocked out of place. What you can do is to turn the copier off and disconnect the bottom 2 trays from the main body of the copier and turn it back on and just use the top 2 trays. You can change the trays lay out to what ever size you want, but make sure you change the BLUE DIAL to the correct size you want to use. I belive the sensor is toward the front of the copier right by the edge of the door, it may be knocked out of place or the flag on the door is broken off or one of the door pins are broken and the door is not closing correctly.... Good Luck..
SOURCE: Close tray error when printing.
http://forums.xkcd.com/viewtopic.php?f=20&t=14495&start=0&st=0&sk=t&sd=a
Go here, it covers your problem in detail
SOURCE: Canon np6030
Most likely, you have a problem with the scanning lamp.... When you turn the copier on, will it turn right off? If so, try to hold the power switch "ON". The Display pannel will flash a Error Code... It may be a E0200 or E0220 or E000. Get the Error Code and get back to us... I think you have a heat or scanning lamp is shorting out... Good Luck
SOURCE: i want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
