Power will not stay on. If I open the front door (Toner Compactment) The paoer stays on, with the instroction to close the front door appearig on the display.If I slowly close the front door with the left side fully contacting the magnet and the right sight barely touching the magnight the power stays on. As soon as the right sight of the fron door contacts its magnet, the power shots down.Please help. James
Posted by Emeka on
  • Emeka Oct 30, 2007
    I have Canon NP6230
    I pressed the switch under the counter (contrast switch) and nothing happened.
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,363 Answers
You did not mention what type of machine you have, but, sounds to me like you have a fuser problem. With a Canon ( which is what it sounds that you have) you need to open the front door and press a service switch on the left by the counter and see what the code is.
Posted on Oct 29, 2007
  • CheckitRight
    CheckitRight Oct 30, 2007
    I was sure it was a canon, no , there is a pinhole under the counter put a paper clip in it to activate. It will bring you into the service mode.
    It's been awhile since I've worked on a canon, so I don't recall the exact steps.
    after getting in the service mode try to push on the clear , stop or #  to see if it gives you a error code.
    and check this list for what it is:
    http://www.copier-help.com/copier-help/e...
Why Bottom freezer drawer wont stay open
Freezer and refrigerator doors aren't usually supposed to stay open. The units are usually installed so that they're slightly tilted to the back to make sure gravity will close the doors if you forget to. If you are SURE - I mean really SURE - that you want your freezer to stay open you should check the drawer rails to see if they're adjustable; if they are, trying raising the back of the rails (or lowering the front). If the rails are not adjustable, try adjusting the front feet of your fridge so that the front of the whole unit is just a tiny bit lower than it is now. Don't lower it too much! If you do, the doors won't stay closed; they'll leak cold air and you'll lose food.
Jul 18, 2014 | LG LMX31985ST Super-Capacity 4 Door French...
MFC 7820n 'close back door error'
Hello Daysinn,
The "back cover open" message is usually caused by a paper jam inside the printer.
Follow these steps to rectify the problem.
1. Unplug the power to the printer.
2. Open the back and front cover.
3. Remove the drum and toner, this may be difficult because it may be stuck; don't be afraid to pull hard, you wont break anything.
4. Check for any foreign objects, most likely a peice of paper.
5. Reinstall the drum and toner.
6. Make sure to close the front and back covers.
7. Turn the power back on.
If the message stays after all this, there may be a sensor not working.
Thanks,
Pat
Mar 25, 2010 | Brother MFC-7820N All-In-One Laser Printer
I just replaced the toner. Toner light on
Keep opening and closing the front door until the toner catches up. Did it have a plastic seal that you forgot to pull off?
Nov 25, 2009 | Copystar CS-1810 Copier
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Mar 17, 2009 | Brother HL 5250DN Laser Printer
Low toner msg stay on
open front cover, press "options" button & press "start" then enter "1" then "0". when display shows accepted, close cover.
hth,
razors
Feb 18, 2009 | Brother IntelliFax-2820 Laser Fax
Toner light stay on
1. Power Unit off
2. Open front cover
Jul 29, 2008 | Brother HL-2040 Laser Printer
Toner
open the door remove the toner cart. and make sure there is nothing is blocking the toner sometimes the end cap from the old toner stays in there blocking the path. good luck
May 17, 2008 | Ricoh Aficio 1515 All-In-One Laser Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
Sep 13, 2007 | Brother HL-2040 Laser Printer
63 people viewed this question
Ekse
Marvin
Marvin
