Ricoh Aficio SP C811DN Laser Printer Logo
A
Anonymous Posted on Dec 02, 2013
Incompatible usb drive has been connected - Ricoh Aficio SP C811DN Laser Printer
Fuji A370 incompatibility porblem when upgrade compauter from XP to windows 7
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. And the same procedure is likely to continue working in the future when you upgrade your computer or camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
2answers
I have an error code "Incompatible USB device has been connected"
I have a Recoh MP C5201. I was reading USB pen drive before but now when you slot in ant usb pen drive,it displays that an incompatible usb has been installed.USB has been enabled but can not read it.How can I solve this problem. Regards, Bentil
Incompatible with windows 98
try updating the firmware of your drive or updating the usb drivers if its a usb drive
Hi there, so I pulled a Toshiba MK2006GAL out of my Creative Zen, and I got myself a All-in-One USB Card Reader that has a port that fits right for the Toshiba MK2006GAL HD. Now I connect to my ACER...
Although your drive: http://sdd.toshiba.com/main.aspx?Path=StorageSolutions/1.8-inchHardDiskDrives/MK2006GAL
physically fits into one of the slots in that Card Reader, it is not making any "electronic" connections, i.e,. no power is reaching the Toshiba, and no "data" cable is connected from the Toshiba to the Card Reader.
Similarly, although you can fill your automobile's gas-tank with water, there still is a fundamental "incompatibility" to be overcome.
Yes, Windows is recognizing that you connected a USB device into a USB port on your computer, but that's all that has happened, from Windows "point-of-view".
1helpful
Apollo 320gb external hdd is not recognised by PC . USB is enabled and recognises other devices.
If the drive came with a disk and they usually do I would recommend you install the disk first and after the installation has been carried out you then try to connect your hard drive via your usb port. Good luck. If this doesn't work then there may be incompatibility issues. What version of windows are you using? Andrew
Nokia E51 - data transfer / back up problem
when u connect data cable phone ask choose option choose nokia pc suit
Install Maxtor One Touch 4 Save Your Life
Use the preferred method of connecting the drive to your PC. But if it asks you to install the software first, then disconnect the drive, install the software, then install the drive, and start it going again.
It should work fine.
Except ... if you only have USB 1.10 and it asks for USB 2.0. Then you have a problem, as that slight incompatibility will stop it from working properly.
-a.
1helpful
Philips Mobile Storage Device SPD5300CC/96K Incompatible XP?
After consultation with the shop which sold the drive, they helped me work out the problem. Which was that the drive I was attempting to use in the Philips enclosure, had an OS on it, which was conflicting with the OS on my current HDD. So, that particular drive will need to be connected another way to access the information.
Jvc gz-mg130 and jvc cu-vd20
I had this problem with the GZ-MG505AA (connecting to WinXP SP3). I tried a different USB cable and it worked first time.
Not sure what is different about the cables (the original cable worked fine with my WM 6 mobile phone).
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
