20 Most Recent Ricoh Aficio SP C811DN Laser Printer Questions & Answers
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Ricoh Aficio SP... | Answered on Oct 09, 2019
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
Ricoh Aficio SP... | Answered on May 09, 2017
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Ricoh Aficio SP... | Answered on Apr 10, 2017
format the drive from the machines system and restart.
if this does not work call 0243494871 for the part or any other ricoh technician for help.
thanks and all the best
Ricoh Aficio SP... | Answered on Aug 02, 2016
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Ricoh Aficio SP... | Answered on Nov 06, 2015
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Ricoh Aficio SP... | Answered on Jul 08, 2015
drum blade bad replace it or drum unit
Ricoh Aficio SP... | Answered on Apr 06, 2015
push Menu button, then push down arrow to panel 4/4. The last option is "Language". Click OK, then you will see a list of languages with English at top. Select English and click OK
Ricoh Aficio SP... | Answered on Jan 21, 2015
The transfer belt is not calibrated or the ID sensors are dirty. Read the user manual on how to calibrate it. No manual? Go to ricoh-usa.com
Ricoh Aficio SP... | Answered on Nov 23, 2014
go on line to the manufacturer and look up your model and down load the service manual
Ricoh Aficio SP... | Answered on Jul 03, 2014
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Ricoh Aficio SP... | Answered on Apr 04, 2014
fuser encoder error
-replace Encoder Ferrite core switch - B2234240
-replace Photo interuppter - Horizontal 7mm AW020190
Ricoh Aficio SP... | Answered on Mar 03, 2014
Ricoh Aficio SP C811DN Laser Printer Logo
72 questions posted
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
amir hamza
amir hamza
Ekse
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
fix error message set pcu correctly
  • Office Equipment & Supplies
