Canon PIXMA MP830 All-In-One InkJet Printer Logo
A
Anonymous Posted on Mar 06, 2014
Pink lines when printing with my epson 710 series
Why my epson 600 workforce prints pink or magenta
printer mixes colors to get final color. So if it prints Magenta then it may be missing Blue or Cyan. Try printing a blue color or a Cyan.
Suggest forcing printer to do a deep clean if ink tanks are full.
"Open the Applications folder, open the EPSON Printer Utility3, select WF 600 Series, and click OK. Then select Head Cleaning. 3. Follow the on-screen instructions to start the cleaning cycle, which lasts around 2 1/2 minutes."
from
https://files.support.epson.com/htmldocs/wf600_/wf600_00ug/WF600.1.158.html
Set up Epson XP-710 for non Wi-Fi use
you need to buy a USB-cable and connect the printer with it to the PC - see picture
- then download a driver at the link below:
http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/support/12463
Expression Premium XP 710 set-up-epson-xp-710-non-wi-fi-use-cetraao0zsf5cxvgwz0wg4tf-1-0.jpg
Why does the printer (EPSON Artisan 710) print out a sheet with writing on the same side when I choose double-sided priting?
test it with 2 pages of text, one page with an "A" on it, then the 2nd page with a "B" on it. once they print out, flip them over and run them thru again to see which side of the paper is being printed on during a pass thru the printer.
I get horizontal yellow lines all the way down the page with my epson stylus dx6000 all-in-one printer on all pages printed.
Not sure if the situation we're in is the same. I have a similar problem, but instead of yellow lines, it is pink lines. printer is Epson RX510. The lines are more prominent if the print quality mode used is best and if the document to be printed requires the affected color. Upon consultation with the printer technician, I was adviced that it is the print head which has a problem, and changing it is costly and the repair duration even depends on parts availability. With that, I just decided to use the printer just as is. Hope this info helps.
1helpful
Epson Stylus dx4400 Printer printing in pink
have you tried nozzle check? it should tell you that the inks are not printing correctly it will print on a pattern of lines if there are gaps and breaks on the lines it means that you have to clean the heads. check on your manual how to do it. what is your operating system on your computer? Windows or Mac?
Epson 6400
My printer wont print balck.......it prints the other 3 colors. What can I do to fix it.........I have cleaned the heads and done everything I know t do. HELP!!!!
7helpful
2answers
Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
old marine
old marine
ZJ Limited
ZJ Limited
