20 Most Recent Epson RX620 All-In-One InkJet Photo Printer Questions & Answers
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Epson RX620... • Answered on Apr 02, 2021
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Epson RX620... • Answered on Jul 18, 2019
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Epson RX620... • Answered on Nov 27, 2017
You need a Driver update, go to : http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&BV_UseBVCookie=yes&infoType=Downloads&platform=OSF_M_X9 where you can download the latest driver ( if the link above doesn't work for you, just go to Epson.com-Divers and Support-enter in your model #-it should show your Operating system in the box, if not, use the arrow to scroll thru until it you find what you are running and click it-Then click on the printer driver and update your driver. I have 3 of the RX580's and have worked on the RX595's & 620's (they are exactly the same except for color) and have had this same problem after an OS update or a Driver update. Getting the newest driver should cure your problem, although one time I actually had to revert back to an older driver for Windows XP. Don't forget to reboot after you get the new driver.
Epson RX620... • Answered on Aug 15, 2014
Describe what YOU call CD covers? There is an anomaly here. Are you simply printing onto a4 paper for jewel case inserts or do you mean actually printing onto the CD.
Epson RX620... • Answered on Aug 03, 2014
To Any & All of you that need a driver for any Epson Printer ( I currently have 2 RX580's -1 with refillables & 1 with a CISS and I have had a CX, a WorkForce, an Artisan & 2 NX's in the past) just go to their website and download the drivers. Here's the link for the Windows 7 driver page ( you can also get Drivers for Windows XP there) and the Epson Link should detect your Operating System on its own: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=44341&prodoid=54782584&infoType=Downloads&detected=yes&platform=OSF_W_7-64 Just click it & follow the simple directions. Once you get the Driver, then download any utilities that they may have for your All-In-One Printer, like = Easy Print, PrintCD, etc. etc. NOTE: You should choose the 1st option they give you as it usually is all inclusive and normally is the same thing you would get if you had the original disk in your hand. But after you download it then check the "Utilities" Tab and see if there is any extra's for your particular model. It should also be noted that for just basic printing, Windows 7 will provide you with a driver for your printer by just going and hooking up the printer to your computer and letting Windows Update find them for you. Here's How To Do That: Printer drivers for most models (and not just Epson) are included in the Windows 7 operating system. Follow the instructions below to install the Windows 7 printer and scanner drivers.
  1. Make sure your computer is connected to the Internet.
  2. Connect your Printer to your Computer, Plug in your Printer and turn it on.
  3. Click sw_startbutton_1_er.gif (or go to your Control Panel) and select Devices and Printers.
  4. Select Add a printer.
  5. Select Add a local printer or Add a network, wireless or Bluetooth printer. Mine choice was " Local Printer".
  6. Choose your printer port.
  7. Click Windows Update and wait for the printer list to update. The update may take a few minutes.
  8. Select EPSON as the Manufacturer, then scroll through the list of Printers and select your product. Follow the on-screen instructions to complete the printer driver installation.
  9. Note: Your product may also have an available scanner driver that is built into Windows 7 known as WIA.
For All Versions of: Windows 7 32-bit, Windows 7 64-bit I hope this helps some of you out as I know it's sometimes hard to hang on to those Disc ( or maybe you got the printer used and it didn't come with one....). If anybody needs any additional help just drop me a line and I'll see what I can do for you. Brian [email protected] (My Experience Level....I built my 1st computer in 1998 with 13 bags of parts and a beige box for $300 and it was a beast back in the day.....) now @ 200 + Builds, plus when I was in College in 1984 I use to write FORTRAN & BASIC programs with a TRS80 that had a real pretty GREEN SCREEN.....lol I hope this helps
Epson RX620... • Answered on Jun 20, 2014
is both the light blink the same time or blink alternate ? if blink the same time, it's probably a fatal error..
if blink alternately then the waste ink counter need to be reset and the waste ink pad need to be replaced.
Epson RX620... • Answered on Jun 04, 2014
Have you checked that each computer will print when connected directly?
Epson RX620... • Answered on Apr 11, 2014
Dear Lisa, First, please allow me to apologize for the inconvenience. At FixYa we do our best to maintain a clean atmosphere on the site and to make sure that all information provided on the site is unique and genuine. However, there may be some cases where users take advantage of the free forum we provide by posting spam, self-promotion information or advertisement. These cases are not many and most importantly, are easy to notice. If you come across such posts that include advertisements or self-promotion, we will appreciate it if you could report the thread as abusive by clicking the little flag next to the question. In any event, please know that I already blocked the user who answered your previous post and deleted all his answers. Experts and users on FixYa are sharing their knowledge and information voluntarily and by their own free will. By doing so, they are assisting people all over the world with everyday life issues. Please note, the information, tips and links on FixYa are posted by users and Experts and not by FixYa. Choosing to accept a solution or clicking a link within a solution or a thread, is your own choice and responsibility. Please rest assured that we are doing our best to keep the site clean and making sure FixYa continues to be a household name for solving problems. I hope you'll have a great FixYa experience! For further assistance, please feel free to contact us directly at: http://www.fixya.com/contact
Epson RX620... • Answered on Dec 31, 2013
sounds like the printheads need to be replaced. just replacing the ink cartridges won't fix it.
Epson RX620... • Answered on Dec 30, 2013
This message comes up after about 40000 registers on a use counter. I posted what I did on the Epson RX620 forum. Look it up. Basically I bought a repair manual on the net for about $10.00 I used this to take the RX620 apart down to the waste ink catch pads which I removed cleaned dried and replaced. It was a long job the first time and you need the manual in order to figure out how to do it. My pads were only about 1/3 used but I live in a dry climate. So punch those override buttons and keep going. You might put a plastic sheet or pan under the printer to catch the waste ink when it actually does leak out.
Epson RX620... • Answered on Dec 29, 2013
Here's some thoughts that may or may not help you. =) You could double check the Print quality and make sure it's at the highest. If the printer head is removable, you could take it out and clean any build up gunk on there. Sometimes it build up around the edges of the printer head. If it's an old printer it may just need a new printer head. But they are not really worth replacing since they cost as much as a new printer. Not much else you can do other than have the printer self clean itself.
Epson RX620... • Answered on Dec 05, 2013
Epson RX620 All-In-One InkJet Photo Printer Logo
163 questions posted
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Photo Epson
  • Photo Epson
Most Popular Question
2 red lights blinking
  • Office Equipment & Supplies
