A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection. If
that doesn't help, try the steps below: 1.
Disconnect the printer from your computer. 2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds). 2.
On your computer, go to Control Panel > Printers and Faxes. 3.
Delete the Lexmark print object. 4.
Reboot your pc. 5.
When your pc turns on, reconnect the printer. 6.
Wait until your pc fully recognizes the USB connection. To check, go to Control
Panel > Printers and Faxes. If you see a new Lexmark print object in the
list, then try to print/scan again.
1.
From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2.
Touch USB-Connected Computer or the name of a network computer. The local or
network computer is the destination that will receive the scan. Wait until the
printer has finished downloading a list of the scan applications available on
the selected computer.
3.
Select an application (in your case your email), and then touch Accept.
4.
Select the color, resolution quality and the original image size. If necessary,
touch Accept each time you make a selection.
5.
Press the start button to start scanning. The scan is complete when the application you selected
in step 4 opens on the destination computer, and the scan appears within the
application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1.
Click Start.
2.
Click All Programs or Programs, and then select the printer program folder from
the list.
3.
Select Printer Home.
4.
Choose your printer from the printer drop-down list.
5.
Click Email, and then select Photo, Document or PDF.
Note:
You can select Document only if an OCR application is stored on your computer.
Scanning starts and the scan progress dialog appears.
6.
When the scan
is finished, a new e-mail message is created with the scanned document
automatically attached.
7.
Compose your e-mail message. Note: If your e-mail program does not open
automatically, then you can scan the document to the computer and then send it
through e-mail as an attachment.
For
Mac:
1.
From the Finder desktop, double-click the printer program folder.
2.
Double-click the printer Center to open the All-In-One Center.
3.
From the "What is being scanned?" menu on the main screen, select a document
type.
4.
From the "How will the scanned image be used?" menu, choose To be viewed on
monitor/web page.
5.
From the "Send scanned image to" menu, choose an application.
6.
Click Scan.
7.
Retrieve the scanned image from the application, and then send it through
I hope this information has been helpful.
Start,
control panel, device manager.
Go to the USB Controller section and click the + sign.
Go to each USB Root Hub and right click on it, left
click properties, left click power management. Uncheck the box, allow
computer to turn off this device to save power.
Restart your computer.
Start, control
panel, device manager. Click on Network and then right click on your
wireless adapter, left click properties, power management. Uncheck
the box, allow computer to turn off this device to save power.
Need more help, try posting at...
Dell Printers Forum
Rick
