20 Most Recent Lexmark X4690 Wireless InkJet Printer Questions & Answers
to end a printer task , go to add printers and devices , click on the printer click "see what is printing" and stop print or delete print from there
it may be a communication probkem with the printer in that that comaptibility has been change to the win operating system
check by getting printer up right click to get the properties tab up and click on the compatibility tab
click the square and highlight the system you have , apply and ok
when on the printer click on driver update as well
Lexmark X4690... | Answered on May 21, 2017
You should call on ((+1-800-585-2494 )) Toll Free Lexmark and get help for Lexmark,
Lexmark X4690... | Answered on May 09, 2017
Try to print an alignment page or self test page to confirm the printing operation of the printer. If still nothing it may need a cleaning.
Lexmark X4690... | Answered on Dec 17, 2014
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Lexmark X4690... | Answered on Dec 13, 2014
Using the printer control panel
1 Load plain Letter-size paper.
2 From the printer control panel, press , and then press .
3 Press the arrow buttons until Clean Cartridges appears, and then press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
4 Print the document again to verify that the print quality has improved.
Lexmark X4690... | Answered on Oct 11, 2014
hit the cancel button
Lexmark X4690... | Answered on Apr 03, 2013
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Lexmark X4690... | Answered on Nov 12, 2012
i had same issue,even after updating drivers from web site.
I solved it by downloading adobe reader,rebooting pc,then(and this is very important)unplugging the printer,AND the router for about 1min.
When i started the scan again,i selected the "scan to adobe reader"option.It all works fine,im thinking of leaving the printer unplugged from the mains till i use it,and the wireless router of course.I have a lexmark all in one x4690.
Lexmark X4690... | Answered on Sep 20, 2012
Alignment problems happens if the cartridge is defective. Try to replace the cartridge and make sure that it's a genuine Lexmark cartridge.
You can also try to reseat the cartridge and clean the contacts.
Lexmark X4690... | Answered on Sep 11, 2012
Make sure the Lexmark X4690 scan software is already installed on your computer. You can insert the install disk that came with your printer to install the Lexmark OCR scan software used for scanning documents to your computer.
For the instructions on how to scan, you can refer the Lexmark X4690 user's guide which can be accessed (on Windows) by going to the Start menu -> Programs -> Lexmark X4600 Series -> User's Guide. Scroll to page 87 for the instructions on how to scan.
You can also download the Lexmark X4600 Series User's Guide for free using this link.
I hope this information has been helpful. Thanks.
Lexmark X4690... | Answered on Apr 15, 2012
Leading cause of paper jams and misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Lexmark X4690... | Answered on Jan 27, 2012
Actually, the power cord plugs into the printer's power adapter. Please see image below:
If you lost the power adapter, please contact Lexmark Technical Support Center for assistance.
I hope this helps.
Lexmark X4690... | Answered on Jan 18, 2012
You'll need to install the printer driver on your computer. From there, the Lexmark software will give you step-by-step instructions on how to install and setup your printer.
Please visit the Lexmark website to download and install the Lexmark X4690 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
After installing the printer driver, try to print a document to verify that the software is installed successfully.
Lexmark X4690... | Answered on Jan 11, 2012
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC.
It could also be that your printer is positioned too far from your wireless router/network. Make sure your printer is placed where it receives excellent wireless signal strength (avoid physical obstructions whenever possible).
Try to check these articles from the Lexmark website for other troubleshooting steps: - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products - How to identify a Wireless Communication Problem and Resolution Tips
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Lexmark X4690... | Answered on Oct 13, 2011
Lexmark X4690 Wireless InkJet Printer Logo
142 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
install lexmark x4690 without cd
  • Office Equipment & Supplies
