Not work, in display printer shows error 5b00. I can't go to nv ram setting. Can you help me?
It means the ink absorber is full.
Under the ink cartridge during its resting position you will find the ink absorber pads. Remove and replace this pads. You can clean it under running water and soap if you don't want to buy.
After that procedure, if the error did not go, you will need to reset the nv ram of the printer
To
do this:
Turn on printer
Press menu button the printer.
Press scan
button,
then press copy
and then scan button again to enter the service
mode.
Use > to go to NV RAM access.
Set abs-m level to 0.
Set abs-p
level to 0.
Press stop to exit.
That should fix it.
Please rate this answer.
thanks
Canon printer error 5b00 could be because there are ink spills on your printer or because the ink absorber is full or the waste ink counter has become full. Follow the simple steps to fix canon printer error code:
·Reset the waste ink counter
·Manually clean the waste ink pad
Read more canon printer error codes and their solutions.
Send reset file
