Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
This means that the Magenta Ink Stick Count fails
Make Sure to Use Phaser 8560 Ink Sticks
Make Sure the Ink Sticks Slide Properly
Remove any Broken or Partial Ink Sticks From the Ink-loading Bin
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
