20 Most Recent SHARP MX-3100N Questions & Answers
Hello. My Sharp mx2300 dont stop warming up after stuck
SHARP MX-3100N | Answered on Jun 21, 2018
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
SHARP MX-3100N | Answered on Jan 29, 2017
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
SHARP MX-3100N | Answered on Jan 11, 2017
image cartridge cyan need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SHARP MX-3100N | Answered on Mar 13, 2016
re install the drivers, and check your files does this happen with word doc or pdf
SHARP MX-3100N | Answered on Mar 11, 2016
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
SHARP MX-3100N | Answered on Jan 30, 2016
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
SHARP MX-3100N | Answered on Feb 26, 2015
Retry mode is something the machine will do if you're faxing to a number that is busy, or to a number that the fax cannot immediately connect to.
Copier Collin Houston TX Copier and Imaging Expert
SHARP MX-3100N | Answered on Feb 10, 2015
Which windows platform.
SHARP MX-3100N | Answered on Jun 27, 2014
Is the copier locked, do you need to input a user code to use the copier?
If so, you need to enter that user number in the job handling tab of the printer preferences page.
SHARP MX-3100N | Answered on Jan 29, 2014
First check with a new yellow drum.
SHARP MX-3100N | Answered on Jan 07, 2014
40 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
fix sharp mx 3100n printer message
  • Office Equipment & Supplies
