20 Most Recent
Xerox Phaser 3100MFP/S Laser Printer Questions & Answers
HOW TO CHANGE LANGUAGE
Press the down arrow on the circular button pad, enter the number 203 using the number pad then select the language using the up and down arrows. Press "OK" to confirm.
I have xerox phaser 3100
The problem is with the hardware of the printer and all you can try is to reset the scan settings on the scanner .. clean the scan bed.
If neither of them works then it might be time to buy a new one.
I have hte xerox phaser
13 Memory full The machine memory is full (there are too many documents that have been received but not yet printed, or waiting to be transmitted).
Print the received documents.
Delete or transmit in immediate mode the documents waiting to be transmitted.
14 Memory full Received document memory saturated.
Why doesn't it scan correctly?
Hi Anonymous,
This is really difficult to answer without seeing the problem first hand.
If you suspect a possible problem with the scan motor then you could switch off completely remove the mains plug. remove the scan glass carefully clean it (It's always worth a clean both side when you have it removed.
Now mark a tiny on the metal work where the sense carriage is parked up at, so you can move the carriage manually and return it back to the start position.
Now once you have axis to the sense carriage you can move it slowly and I mean slowly across the scan table all the way to the other side, it should be smooth running once your part way across you could take a look at the mirrors if your confident enough carefully clean them with a lint free cloth. (use, hardly any pressure on the cloth to remove any dust)
Now when you get to the point where your scanner stopped when under power, can you feel anything that would bring your mirror carriage to a halt at this point.
If it's nice and smooth then return it back to the starting mark you made earlier replace the glass and switch back on.
Once your printer has returned back to ready, try another scan
If not look for error messages and go from there.
Finally try and work through the service menu something that would checkout the action of the scan unit.
Good luck.
On Xerox Phaser 3100mfp., after
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
