Question about SHARP MX-3100N
What does error code dc on sharp 3100n mean?
Getting an error message of maintenance required with code DC on Sharp MX3100N. Please advise how to resolve and what it means
Norman J Weimar Jr
  • Sharp Master
  • 6,960 Answers
Image cartridge cyan need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 13, 2016
1 Related Answer
lilgto64
Matt Wolanski
  • 3 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Posted on Oct 11, 2012
Why is when sent to printer of the Sharp Mx3100N it is not showing in Job Que, but is showing on the computer. How do I fix this?
re install the drivers, and check your files does this happen with word doc or pdf
Mar 01, 2015 | SHARP MX-3100N
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
What is maintenance code of DC on Sharp 3100N
This is a scheduled maintenance programmed into all of these machines. It pops up when the machine crosses a certain "milage." If your machine is still making nice copies and prints it's nothing to worry about.
Copier Collin Houston TX Copier and Imaging Expert
Jul 04, 2014 | Sharp Office Equipment & Supplies
Printing data light is blinking
Check if the machine print is put to paused, go to status and make sure you it is on resume not paused.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Dec 12, 2013 | Copystar Sharp MX-3100N Copier : Sharp...
Error code E7-06 sharp copier MX3100N
The problem is either a corrupt print job that the copier is trying to process or the copier's hard drive is faulty.
Firstly, turn off the copier, check all P.C's that are connected to the copier & purge any print jobs that are currently spooled on the P.C's. Next, turn on the copier & see if it comes ready. If it does, try to print a known document from a P.C. If the error occurs again then I would suspect the hard drive on the copier is faulty.
Hope this helps.
Dave.
Aug 07, 2017 | Sharp Mx-3100n Color Copier Super...
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
What does maintenance code DC mean on a Sharp MX2600N
http://www.printcopy.info/?l=en&mod=docs&brand=Sharp&prefix=MX&gID=19349
Above is the service manual, and below is your user manual, the information you require will be in them.
sharp-world.com/products/copier/.../MX3100_2600N_CTLG_S.pdf
Jun 22, 2010 | Office Equipment & Supplies
508 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
