Registration errors. Have tech come out clean IDC sensors and replace black i/u
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
SOURCE: code error p9 p21 p16 c203 what can i do?
The p error codes you have are due to the test pattern being put on to the transfer belt to check the image density control
The first thig to do is to check and see the condition of the transfer belt and if it has reached life or looks bad replace it also on taking out the transfer belt directly where it goes in there is a cover slide the cover and clean out the idc sensors imgae density control sensors
Also there is firmware to correct the issue do this last the above will get rid of your issuesAlso add toner to all the units manually add the toner as well
