20 Most Recent Konica Minolta Bizhub C550 Questions & Answers
bright light under the big glass is out or bad
Konica Minolta... | Answered on May 04, 2020
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
Konica Minolta... | Answered on Sep 15, 2019
konica minolta bizhub c654e in display error c9401
no Utility/Counter key. howcreset I resolve lamp already change
Konica Minolta... | Answered on Apr 04, 2018
replace the black image unit and clean sensors under the transfer belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 11, 2018
replace the fuser unit then reset the machine
Konica Minolta... | Answered on Mar 10, 2018
sir/mam
under the big glass is large device to your right with lens on it. That is the CCD that reads the orignal document your code deals with that have tech come out DO NOT TOUCH Those RED screws!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Konica Minolta... | Answered on Feb 25, 2018
You had a board replaced an some one or you forgot to remove the chip from the old board and place it on the new board which tracks count serial number really important info.
REPLACE THE DRUM UNIT/IMAGE UNIT TONER WILL NOT FIX THAT PROBLEM for Black
Konica Minolta... | Answered on Jan 24, 2018
Konica Minolta... | Answered on Jan 23, 2018
Fan! Rear of machine TOP. Middle fan
Konica Minolta... | Answered on Mar 11, 2017
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Konica Minolta... | Answered on Feb 23, 2017
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Konica Minolta... | Answered on Oct 26, 2016
After doing this the code comes back replace the Exposure lamp assy. big bright light under the glass.
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Konica Minolta... | Answered on Sep 28, 2016
Konica Minolta... | Answered on Jul 05, 2016
check the log and the log can give you details as to why the scan did not go thru
Konica Minolta... | Answered on Jun 29, 2016
replace the LASER assy. or what is called the printhead
Konica Minolta... | Answered on Jun 25, 2016
Konica Minolta Bizhub C550 Logo
132 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
clean ps45 ps46 in c451 located in
  • Office Equipment & Supplies
