My bizhub c451 issue error code p21,p7,p8 please kindly help me
Posted by Victor Oloruntoba on
Ruban asai
    New Friend:
  • 3 Answers
P6 P7 P8 P21 and just printing black and white. How can i fix it? Hi this is ruban from tamilnadu...09944001031.... Try this 1. Go to service mode (utility -- counter -- 00 -- stop--01 -..) image process adj-- transfer output fine adj-- primary adj-- all colour (-7) set and off main power ... Then On 2 times Redy... (Sorry I dont no English)
Posted on Mar 19, 2018
Dick Monti
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Get support for your Konica here:
https://www.biz.konicaminolta.com/download/users-guide/
Good luck.
Posted on Jan 03, 2018
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
Anonymous
  • 7 Answers
SOURCE: Job error code on a
is this when trying to scan be more specific
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
Anonymous
  • 19 Answers
SOURCE: jumper P2,P7,P8, where do they go
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
alkllklju5
Posted on Sep 07, 2009
Ty Schmidt
  • 118 Answers
SOURCE: i am facing p21 error
This is a very common probem. it needs the IBT sencor cleaned. it is super easy if you need help contact me
Posted on Oct 16, 2011
My c353 konoca Minolta is showing p7, p8, p21 and it print test page with black and cyan only.
Replace the black drum and developer unit along with the magenta (P-7) and yellow (P-8) image units and Transfer belt (P-21)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 07, 2017 | Minolta Office Equipment & Supplies
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
My copier can't print yellow color and p21 and p8 show on the screen. any clues
P21 & P8 are errors of yellow drum cartridge, replace yellow cartridge.
Aug 04, 2015 | Konica Minolta BizHub C650 Copier
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure
Feb 23, 2015 | Konica Minolta Bizhub C451...
I am facing p21 error in my bizhub c451 pls help me
p21 is stabilization failure. Try and clean the IDC sensors that sit below the transfer belt. also you can initialize and stabilize a few times in service mode as sometimes this can rectify a P21 issue. If all fails then it could be the actual ITB causing the issue
Apr 05, 2014 | Konica Minolta Bizhub C451...
Error code:P21 and P8
try to go to your printers and faxes it is located in the start menu.
Apr 03, 2014 | Konica Minolta Minolta Bizhub C253 Copier
[email protected]
my c350 bizhub will not print color. the machine status shows P6 P7 P8 how do i fix this problem
Sep 10, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Jumper P2,P7,P8, where do they go
  4. MSI Motherboard
  6. via
alkllklju5
Apr 13, 2009 | Sony PCV-RX450 (T-9986-078-5) Motherboard
763 people viewed this question
jasbo
jasbo
Marvin
Marvin
