Question about Konica Minolta Bizhub c203 Copier
Code error p9 p21 p16 c203 what can i do? - Konica Minolta Bizhub c203 Copier
walter jansz
    Scholar:
  • 177 Answers
The p error codes you have are due to the test pattern being put on to the transfer belt to check the image density control
The first thig to do is to check and see the condition of the transfer belt and if it has reached life or looks bad replace it also on taking out the transfer belt directly where it goes in there is a cover slide the cover and clean out the idc sensors imgae density control sensors
Also there is firmware to correct the issue do this last the above will get rid of your issuesAlso add toner to all the units manually add the toner as well
Posted on Feb 12, 2011
  • walter jansz
    walter jansz Feb 12, 2011
    you need to go into the tech rep mode and add the toner to all units
MY MACHINE KONICA MINOLTA SHOWS MACHINE STATUS P9 AND P21. WHAT CAN I DO?
Registration error. run registration adjustment in service mode. Recommend a tech do that
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 13, 2017 | Konica Minolta Office Equipment & Supplies
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
How do i solve a p9 and p21 error code
You remove the PRINT HEAD????? DID YOU FOLLOW THE Service manual????????? Well you caused your own problem now you need to do a alignment. of the colors. you also might check the ribbon cable you removed and all the connectors you played with and check each one is secured. Recommend you don't ever remove the print head which houses the LASER unless you follow the service manual. Well you need to get to service mode and run registration procedures. try this site for a service manual or better yey have tech come out and run the required checks.
Service manuals electronic components datasheets and equipment schematics...
Apr 28, 2016 | Konica Minolta Bizhub C550
Hi piz Error code P9 and P21 appears on screen and
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Aug 08, 2014 | Konica Minolta bizhub C250 All-In-One...
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
C451 p9 p21
clean the sensors under the transfer belt
Apr 05, 2014 | Konica Minolta Office Equipment & Supplies
Printing blank
Sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it, unless you know what your doing
Feb 12, 2014 | Konica Minolta bizhub C250 All-In-One...
Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
replace the black image unit and clean the transfer belt sensors located under the transfer belt
Nov 23, 2013 | Konica Minolta Bizhub c203 Copier
Error code p21
This is a color registration error. You can try cleaning the PH units and registration sensors but this model had a TSB about PH unit failures. New PH units were shipped to dealers for every machine they had in the fleet for field repair. If your copier didn't get the new PH units during the "recall" period you will have to pay for them. They must be replaced as a set and you are looking at thousands of $ to repair.
Aug 03, 2013 | Konica Minolta Bizhub c203 Copier
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub c203 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
