Question about Konica Minolta Bizhub C451 Printer/scanner/finisher
I am facing p21 error in my bizhub c451 pls help me
Posted by tabrez on
Dave Pomfret
    New Friend:
  • 16 Answers
P21 is stabilization failure. Try and clean the IDC sensors that sit below the transfer belt. also you can initialize and stabilize a few times in service mode as sometimes this can rectify a P21 issue. If all fails then it could be the actual ITB causing the issue
Posted on Apr 03, 2017
3 Related Answers
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
Ty Schmidt
  • 118 Answers
SOURCE: i am facing p21 error
This is a very common probem. it needs the IBT sencor cleaned. it is super easy if you need help contact me
Posted on Oct 16, 2011
viz5445
vishwa
SOURCE: Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
Posted on Dec 19, 2013
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure
Feb 23, 2015 | Konica Minolta Bizhub C451...
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Konica Minolta Bizhub C451/c550 Imaging Unit errors
what errors P??? or C????
Apr 30, 2014 | Konica Minolta Bizhub C451/c550 Imaging...
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
What is the causes of p21 and p6 in konica minolta bizhub c550
replace the black image unit and clean sensors under the transfer belt
Nov 18, 2013 | Konica Minolta Bizhub C550
I am facing p21 error in my bizhub c200 pls help me out
Sep 06, 2011 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub C451 Printer/scanner/finisher Logo
400 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
