20 Most Recent Konica Minolta Bizhub c203 Copier Questions & Answers
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
replace the black image unit and clean the transfer belt sensors located under the transfer belt
check the registration sensor under the transfer belt which must be removed then slide the cover over the sensors away and clean then one in the rear one in the front or they need to be replaced
Konica Minolta... | Answered on Feb 25, 2018
what color
Konica Minolta... | Answered on May 07, 2017
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
Konica Minolta... | Answered on Apr 07, 2017
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
Konica Minolta... | Answered on Dec 14, 2016
Its a failed Power Supply Cooling Fan Motor. Replace the cooling fan with part number 111T80010.
Konica Minolta... | Answered on Nov 29, 2016
C255A: Magenta TCR sensor adjustment failure
1 Reinstall imaging unit
2 Change imaging unit
3 Change PRCB
Konica Minolta... | Answered on Oct 10, 2016
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Konica Minolta... | Answered on Jul 21, 2016
remove the draw and remove the paper
Konica Minolta... | Answered on Jul 09, 2016
power issue or the os has failed, have tech check it out
Konica Minolta... | Answered on Jun 25, 2016
replace the drum
Konica Minolta... | Answered on Jun 18, 2016
Yellow LASER is bad, try a reset open close right side door. if it comes back need to have the printhead for yellow replaced
on the control panel screen is section for you to check the status of print/scan items. you will be sent to a screen you select the job and check details, if this was a scan to email might check the mail server if scan to pc check folder to scan to is a shared folder
C2558: Abnormally high toner density detected black TCR sensor
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
Konica Minolta... | Answered on Jun 09, 2016
The print head (LASER) under the cyan image unit is bad
Konica Minolta... | Answered on May 15, 2016
utiltiy/counter
display details
stop 00 stop01
Konica Minolta... | Answered on May 14, 2016
Konica Minolta Bizhub c203 Copier Logo
207 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
copies very dark
  • Office Equipment & Supplies
