20 Most Recent Konica Minolta Bizhub C451 Copy-print-scan Questions & Answers
There could be paper or tape wrapped around the pickup rollers. Also they just may need some cleaning with rubbing alcohol and a Q tip.
Konica Minolta... | Answered on May 07, 2019
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jul 03, 2018
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
Konica Minolta... | Answered on May 17, 2017
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Konica Minolta... | Answered on May 07, 2017
what color is the stain? mite need a need a new transfer belt or fusing unit
Konica Minolta... | Answered on Apr 13, 2017
First check the Laser window cleanliness,
Then check the IU-Cyan and its charging grid cleanliness.
also try in service mode-Image Processing Adjustment-
Background voltage value can be increased.
Konica Minolta... | Answered on Jan 05, 2017
1. Turn OFF the main power switch (Inside front cover). Ensure sub power switch is on located right side of the control panel)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. If the code come back do NOT reset have a tech come out replace the fuser unit, it can catch on fire that will ruin a Christmas Day!!!!!
Konica Minolta... | Answered on Dec 25, 2016
Black or color or both? Check the transfer roller sponge looking roller on the right side cover that opens
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Can i know any message appearing on screen,
any hour glass symbol?
Konica Minolta... | Answered on Dec 14, 2016
You have to replace it.
Konica Minolta... | Answered on Oct 02, 2016
this problem at/dc you should replace developer
Konica Minolta... | Answered on Sep 17, 2016
Sir/Mam,
Press Utility/Counter, Details, "Stop 00 Stop 01", (Password if required 92729272)
After replacing a fusing unit or transfer belt unit, perform New Release to clear its life counter.
1. Select the key as follows.
[Counter] ? [Life] ? [New Release]
2. Open the front door.
3. Select a unit where New Release is made.
4. Press the Start key and perform New Release. Exit out
Konica Minolta... | Answered on Apr 28, 2016
what media are you using and what is the weight of the media you are using and does the copier know this and is correctly set
Konica Minolta... | Answered on Jan 14, 2016
replace the fuser
Konica Minolta... | Answered on Jan 10, 2016
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Konica Minolta... | Answered on Jul 02, 2015
Konica Minolta Bizhub C451 Copy-print-scan Logo
29 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
in konica minolta c451 am getting black
  • Office Equipment & Supplies
