My MP620 is producing copies and printed documents that are skewed about 20 degrees to the right. The paper is feeding fine, so the problem must be with some other internal part that is misaligned. I called customer support and the person had never heard of this problem. Any advice?
SOURCE: paper feeds unevenly
your printers gears have got mis-aligned or may be even your paper feeder tray is not availble or not fitted properly, for gears problem u get your printer serviced.wish u success!!
SOURCE: not feeding
If your printer doesn't feed with normal printing try a manual line feed. If the print cartridge is moving then there is either a paper jam or check to see if anything has fallen into the paper feed roller. Here's the roller cleaning procedure from Canon for your mode. Please let me know if you still need help after cleaning the rollersl:
Paper Feed Roller is dirty.
You may need to clean the Paper Feed Rollers of the
Auto Sheet Feeder. Follow the procedure below.
Cleaning the Paper Feed Roller of the Auto Sheet
Feeder consumes it, so perform this procedure only when necessary.
Three sheets of A4 or Letter paper are required for
the cleaning. Have them on hand.
(1) Make sure that the printer
is turned on, and then remove any paper from the Auto Sheet Feeder.
(2) Open the Printer Properties
dialog box.
See Opening the
Printer Properties Dialog Box Directly from the Start Menu.
(3) Click the Maintenance tab, then Roller Cleaning.
(4) The confirmation message is
displayed. Follow the instruction on the screen.
(2) Open the Canon IJ Printer Utility dialog box.
See Opening the Canon IJ
Printer Utility (Macintosh).
(3) Make sure that Cleaning is selected in the pop-up menu.
(4) Click Roller
Cleaning.
(5) The confirmation message is
If this procedure does not solve the problem, clean
the surface of the roller with applying a slightly moisten cotton swab with
water to wipe off dust or stain. If the problem still persists, contact a Canon
service representative.
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
SOURCE: skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
