There are a few common HP printer Problems:
1. Streaks through printing - Clean printhead using windex and alcohol swabs.
Run a "clean printhead cycle"
2. Paper jams: Check all paper paths using a flashlight. Remove rear cover or duplexer to get more access. Even a tiny piece of a paper or another object can disrupt the printer functionality.
3. Skewed printing -
Check for the duplex unit or paper path to be fully inserted on both sides. If skewed printing only appears when making a copy, the scanner lamp is misplaced or out of rail.
Paper will not feed.
Try cleaning the paper pick up roller with some cleaning solution or alcohol swabs. Usually does the trick!
Good luck! HP is a good printer.
