Printer says there is a J003 jam, but we have tried for hours and there is no paper jam.
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
SOURCE: paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
