20 Most Recent Ricoh Aficio 3025 All-In-One Laser Printer Questions & Answers
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Ricoh Aficio... | Answered on Oct 19, 2016
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Ricoh AF 3025 error code SC650 is wat problem?
Ricoh Aficio... | Answered on Jul 20, 2016
You can only select a paper size from the operation panel that the machine has loaded in the paper trays. If your are trying to select A3 and A3 does not show up in the list of available paper sizes then either you do not have that size loaded or the paper size dial in the tray is not set properly. These Ricoh's use a paper size dial in each tray that is designed to tell the machine what paper you have placed in that tray. So it is somewhat common for me to hear from people who have this problem because the paper was changed without changing the dial or the dial has been accidentally moved. I would check the paper size dial in each tray to be sure it is correct.
If I have not answered your question correctly please provide more specific info as to your situation.
Thank You for using Fixya.
WheatlandServices
Ricoh Aficio... | Answered on Jul 17, 2015
Under "user tools" hit printer, then print the config page, info is there. -Carl
Ricoh Aficio... | Answered on Feb 18, 2015
As in a toner empty error? Otherwise, it needs a new PCU.
Ricoh Aficio... | Answered on Jan 02, 2015
I would try removing and reseating all the supplies, toner, fuser just to make sure something was not bumped loose while moving.
Ricoh Aficio... | Answered on Jul 29, 2014
Go get the firmware from the ricoh site. Get the rfu file if you are doing it remotely eg. from your laptop or PC. Just make sure nobody is using the printer while you are doing it.
Ricoh Aficio... | Answered on Jul 23, 2014
Please use caution in following the steps above. It is very important if you do not want to expose yourself to airborne toner that you are very careful about what type of vacuum cleaner you use. Many vacuums do not have filters fine enough to capture the toner and it gets blown out into the air where you breathe it in. This is the reason that technicians will be equiped with a small black suitcase vacuum. 90% of that suitcase is filter that traps all the toner.
Ricoh Aficio... | Answered on Jul 05, 2014
open and close all covers including the one on the lower right side
Ricoh Aficio... | Answered on Mar 21, 2014
CHECH THE SENSOR WHRE U PUT PAPER
Ricoh Aficio... | Answered on Feb 12, 2014
That has happened to us if we lay a small item to copy on the glass, so we would lay a 8 1/2 x 11 sheet over it and it would work.
Ricoh Aficio... | Answered on Feb 05, 2014
Ricoh Aficio 3025 All-In-One Laser Printer Logo
79 questions posted
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
error code sc 650
  • Office Equipment & Supplies
