The printer takes from the priority tray if there is a page there, however this is not what I want. I want the printer to take a page from the main tray even if there is a paper in the priority tray.
I am printing letters and their respective envelopes. I don't want to have to manually fed the envelopes for every single print job. Any ideas?
My idea is that you have the wrong printer for the job. Yes. It will automatically take anything that is put into the upper feed section, because it is actually the same feed section- it uses the exact same feed rollers to feed from the bypass tray as the main tray, this is designed only as a convenience for the occasion you want to print different size paper you may want to run, or for re-feeding for duplex
Yes it is a P1006. There is a priority tray (for things like envelopes) and a main tray for letter sized paper.
I think that you might be right, as I have tried different configs, etc and nothing seems to make a difference; if there is paper in the upper feed tray, it will be used. Regardless of the configuration.
Well I can always manually feed the envelopes in the upper tray while the letter size paper is in the main tray. Not the end of the world. It just seems ambiguous from the user's manual that one can automatically (from software) toggle between the source of the paper.
it is not actually a laserjet P1006 is it? There are no optional trays for this printer. What is the model?
