20 Most Recent HP LASERJET P1006 Printer Questions & Answers
Use Premium paper. It is a little bit more expensive, but it will reduce the amount of jams that occur
HP LASERJET... | Answered on May 31, 2019
Check the drivers and see if they are wrong. If so, Change it to HP LaserJet P1006
You need to get it serviced. I have never encountered that problem, but I recommend getting it serviced
I did not know the LaserJet P1006 had upgradable Firmware. I know the newer ones do, but not the LaserJet P1006
Your toner door sensor is broken. I recommend ordering a new one
Clean off the roller. It may not be detecting the paper due to debris on it
Unplug and power off the printer and wait 30 seconds. It will reset the device.
HP LaserJet P1006 is still supported. It can run In Windows 98 though Windows 10. In my answer, I would recommend downloading the Basic Driver. The basic driver allows you to print, manage and doesn't allow anything else to install with it.
Here's the link:
https://support.hp.com/us-en/drivers/selfservice/hp-laserjet-p1006-printer/3435682
Hope This Helps!!!
This may help. Before you disconnected the USB cable did you "disconnect" it using the icon in the system tray? If you did not, try cycling power to the computer with no USB cable for the printer connected. Sometimes when you unplug a USB cable while it is still "connected" to the device your computer will lose track of that USB port. I hope this helps you.
HP LASERJET... | Answered on Nov 13, 2017
you are installing the drivers may be not correct. u remove the printer driver and install the proper driver again otherwise it may be spooler problem then u have to reinstall the os and configure printer dirver
HP LASERJET... | Answered on Apr 07, 2017
It is all explained in my published guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
Now once you have downloaded the driver you will need to double click the saved file to install the driver on your computer.
Connect your printer to the USB port of the computer as well as to the printer and then connect the power.
Your printer uses A4 standard office paper, insert a few sheets.
Then print a document.
Take care!
damnor01
HP LASERJET... | Answered on Jul 19, 2016
To help you troubleshoot the issue paper does not load on the roller, please find the link below:
http://support.hp.com/us-en/document/c02016130
If issue persists, check if printer is under warranty. To check these please find the link given below:
http://support.hp.com/us-en/checkwarranty
If the printer is out of warranty, please contact HP Service Center for servicing the printer:
http://h20566.www2.hp.com/portal/site/hpsc/public/help/contactHP/home?ac.admitted=1459920815636.1123376534.199480143
GuruAid.com
HP LASERJET... | Answered on Apr 06, 2016
MANUAL PRINT IS ALSO KNOWN AS TRAY 1 ON HP PRINTERS. LOAD PAPER INTO THE SLOT ABOVE YOUR PAPER TRAY.
HP LASERJET... | Answered on Dec 14, 2015
I assume that the error is to open the lid of the laser cartridge and check to be torn from the laser sensor has to be a piece of plastic when pressed on the sensor cap ivhizi if the printer should be opened and checked laser
HP LASERJET... | Answered on Dec 08, 2015
Please unplug the printer, wait 2 minutes then plug back in.
HP LASERJET... | Answered on Jul 10, 2015
open toner door pull out the toner ,now remove the paper.
HP LASERJET... | Answered on May 26, 2015
i want hp Laser Jet 1010
HP LASERJET... | Answered on Feb 22, 2014
HP LASERJET P1006 Printer Logo
134 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
print manual feed
  • Office Equipment & Supplies
