I am receiving an error of canon ir 1210- rec. paper jam, slide platen left. while on sliding there are no paper inside, this is an fault signal. how to solve this.
i have canon ir 2016j potocopy machine problem is print out empty paper haw can i solve this problem pleas hep me???i have canon ir 2016j potocopy machine problem is print out empty paper haw can i solve this problem pleas hep me???
You can't post conmments that contain an email address.
Re: i am receiving an error of canon ir 1210- rec.
No canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
after yoy slide, open up the cover and then you will see the cartridge (black color) then you pull out the cartridge (there is a holder steel). and you will see the paper jammed. take it all, do not be left one bit. and then replace all like a before.
Hi
With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out.
Thank you, Steven 805-520-3003
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
