20 Most Recent Canon imageCLASS D661 Digital Printer Questions & Answers
0answers
Paper jam
Be the first to answer 6/15/2017 7:24:03 AM • Canon imageCLASS... • Posted on Jun 15, 2017Be the first to answer
Black line on copy while using paper feeder
try cleaning the feeder glass
12/13/2014 12:08:12 AM • Canon imageCLASS... • Answered on Dec 13, 2014
0answers
Ghost image
Clean the upper and lower fuser rollers.
4/10/2013 6:09:55 AM • Canon imageCLASS... • Answered on Apr 10, 2013
Machine won't clean rollers inside main unit when programmed to do so.
Please follow the steps below to hard reset the printer and let me know the result.1.Remove all the cables from the printer.2.Wait for 10 mins.3.Connect only the power cord and try to power on the printer.4.If the problem is solved, then connect all other cables, otherwise let me know.
8/28/2012 8:45:54 PM • Canon imageCLASS... • Answered on Aug 28, 2012
I NEED MANUAL FOR PRINTER CANON D661
First of all, thank you very much for choosing FIXYA today for your online technical support needs. Here is a direct link to the ONLINE USER'S MANUAL for that model:http://downloads.canon.com/cpr/pdf/Manuals/ICD600_User_Ref.pdf To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual. You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer. I truly hope that was helpful to you Luis. Good luck and take care. Joe.
12/7/2011 9:19:35 PM • Canon imageCLASS... • Answered on Dec 07, 2011
MY PRINTER CANON IMAGE CLASS D611 NO PRINTTING DE
Hello and Welcome to FixYa!Sir/Ma'am kindly explain your query, Is your printer shows some error message or it just prints blank pages without any error message? Before the problem started have you replaced your Cartridge or something you did? Kindly give some detail about the problem you are facing. I will help you according to that.I am here for your help. Waiting of your response.Thanks
12/6/2011 10:33:32 PM • Canon imageCLASS... • Answered on Dec 06, 2011
0answers
Canon Imageclass D661 printer is
How old or how much use does this machine get? The older/more use it gets, the more likely it is to start making random noises and squeaks. It could be a lose belt or just need some lubrication, but it's hard telling where exactly it would need the maintenance. As long as it's printing and copying fine, I wouldn't worry too much about it since it doesn't sound detrimental.
Hope this helps!
8/25/2011 8:16:35 PM • Canon imageCLASS... • Answered on Aug 25, 2011
We are receiving code E110,
This error signals that the laser scanner motor is not responding to commands properly. If it scans then the defect isn't in the motor itself but in its mechanism - it's worn out and the transmission belts slip .
The entire mechanism will have to be replaced - a job for a dealer, they are the only ones with access to replacement parts.
7/14/2011 7:10:01 PM • Canon imageCLASS... • Answered on Jul 14, 2011
0answers
My Canon Image Class D661
Hi Dear
Follow the mention below instruction.
    • 1 First, unplug the power from the printer and all connections (including usb to the PC as well).
    • 2 Next, press and hold the Start button while plugging the power back into the printer.
    • 3 While still holding the Start button, press the Resume button twice (which then allows for Removal of Ink Cartridges(if you are past the limit otherwise leave them in).
    • 4 Now repeat Step 1 and then repeat Step 2 above.
    • 5 Press the Resume button 4 times (note that the light will only blink the first two times of the four times that you press the button)
    • 6 The error should now have cleared so that you can use the printer.
6/7/2011 3:27:31 PM • Canon imageCLASS... • Answered on Jun 07, 2011
Is there a Canon ImageClass
Nope; I just got off of the phone with Canon's tech support. There isn't one and there won't be one.
2/25/2011 7:31:05 PM • Canon imageCLASS... • Answered on Feb 25, 2011
What causes my copier pages to have black smudges
Black smudges are usually caused by a defective or worn out drum. When the drum gets a fingerpirnt, any kind of oil, or anything else that causes the static charge to not hold the toner to the paper, the toner will not go where it is supposed to in order to create the image on the paper and it will cause smudges, streaks or lines.
1/31/2011 2:17:27 AM • Canon imageCLASS... • Answered on Jan 31, 2011
Need replacement disk(s) for Canon Printer
HI there please follow this link for the replacement DISK. LINK
Thank you.
11/18/2010 6:04:07 AM • Canon imageCLASS... • Answered on Nov 18, 2010
Prompt says, "REC. Paper jam
Hi With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out. Thank you, Steven 805-520-3003
10/14/2010 7:43:30 PM • Canon imageCLASS... • Answered on Oct 14, 2010
I not found the counter
Can you please clarify the question? Are you looking for the life page count of the printer? Or are you trying to turn off the toner out message? Need more info in order to properly assist you.
9/30/2010 10:56:08 PM • Canon imageCLASS... • Answered on Sep 30, 2010
System error code E000 on
Hi
Thanks for using FixYa. Error E000 means low temp detected in the fuser unit, Faulty thermistor, lamp or PCB. Check fuser for jammed paper. It’s an issue related to the fuser unit. Try and clear the error by entering the service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistor. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
8/28/2010 6:13:49 PM • Canon imageCLASS... • Answered on Aug 28, 2010
Getting ghost images on copies, meter reading is
Ghosts are normally caused by the fuser but with such a low meter, we'd look elsewhere. Try changing paper or feeding a regular sheet through the bypass tray at a card stock setting.
If the ghosts disappear then that proves that the fuser issues are the best suspects. The fuser/ fixing assembly PN is FG6-7947-150 if it ends up that it's bad.
Whit
Item, Inc.
8/17/2010 10:40:22 PM • Canon imageCLASS... • Answered on Aug 17, 2010
Canon imageCLASS D661 Digital Printer Logo
Popular Tags
44 questions posted
old marine
old marine
Ekse
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
canon imageclass
  • Office Equipment & Supplies
