Just replaced paper exit switch that customer broke,turned on and ran some test prints and after 4 prints the jam indicator came on,i checked all possiable paper jam locations opened all doors and checked fuser unit, now out of ideas,pleas offer some suggesions.thanks kopitech.
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
after yoy slide, open up the cover and then you will see the cartridge (black color) then you pull out the cartridge (there is a holder steel). and you will see the paper jammed. take it all, do not be left one bit. and then replace all like a before.
Hi
With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out.
Thank you, Steven 805-520-3003
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
check as follows. Give by turns several sheets. Localize, where paper is stoped attentively see that can disturb her(its) motion. Follows to pay attention to presence stranger subject ( such can be) , then, when you find, place of the constant grip, analysing reason, can is there jammed ragged paper, can was torn off protection of the corona, it wore slantings gross, please ask, beside who has occurred jam and that herewith occurred. I ?????? with this technology 20 years and always in such events ask, as this has occurred. Most often this reason scrap papers, which is not seen, hereinafter stranger subjects, even feminine emery board and staples. You manage, in this nothing complex.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Xerox 6110
Code
Description
A1-1 to A1-32
All indicate a paper path problem, etc. in the ADF
A2
ADF exit problems
A3
Irregular size documents
A5
ADF interlock
A6
ADF single sheet document reset
A7
Platen interlock
A8
ADF exit interlock
C1
Tray 1 jam
C2
Tray 2 jam
C3
Tray 3 jam
C6-1, C6-2
Jams related to duplex
C6-3
Registration sensor, re tray 1
C7-1, C7-2
HCF feed problems
C7-3
Tray 1 feed problem
C8
Paper stays in tray or duplex or HCF
C9
Bypass feed problem
E1-10 to E1-25
Internal jam
E1-6
Paper on registration sensor
E2
Reset signal happened. Might read E-2 something else
E3-30 to E4-14
Exit jam
E3-6
Exit jam
E4-10 to E4-14
Inverter sensor not actuated
E4-15
Inverter sensor
E4-40 to E4-45
Duplex entry sensor
E4-6
Inverter sensor
E5
Front door interlock
E6-1
Tray 1 interlock
E6-2
2 tray or duplex interlock
E6-3
HCF interlock
E7-2, E7-3
Duplex interlock
E8-6 to E8-15
Duplex entry sensor
F1-1
Sorter entry sensor
F1-6
Sorter exit sensor
F3
Paper size not available for sort/stack
F5
Sorter interlock
J1
Add toner
J3
Replace copy cartridge
J7
J8-1
Wrong copy cartridge installed
J8-2
Copy cartridge EEPROM
L6
Auditron or other counter problem
L8
Platen glass temperature is too high
L9
Communication problem between interimage erase/edge lamps and main board
U1-1
Main motor drive problem
U2-1 to U2-4
Scan home sensor
U3-1
Lens sensor
U4-1
Open fuser thermistor
U4-2
Fuser did not warm up properly
U4-3
Fuser temperature too high
U4-4
Fuser problem. Staying on too long
U4-6
High fuser temperature
U5-1
Sorter bin home switch not activated
U5-2
Sorter bin home switch stayed actuated
U5-3, U5-4
U6-1
ROM problem
U6-2
RAM problem
U6-3
Low battery
U6-4
Incorrect value in NVM. Reinitialize main board with code 20-96
U8-1 to U8-6
Problem with exposure lamp, lamp sensor, lamp board
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
