This happen when I have instable power supply problem
SOURCE: Machine show an error E000002 Model iR2530 Canon
these means the reading of the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has indicated 100
deg C.
2.The reading of the main thermistor is less than 150 deg C
continuously for 400 msec 1.3 sec after it has indicated 140
deg C.
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON the
power.
TO ENTER SERVICE MODE:
press *
press 2
press 8
press *
If you cant clear the error code these means that you need to replace fixing heater.
Hope that helps!
SOURCE: Canon Imagerunner 2220i Error Code E000000-0000
The fixing assy is not reaching temp fast enough, lamp blown or thermal cutout.
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
