HP LASERJET 1022n
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
SOURCE: HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try flashing the firmware: one of the fixes is this - (Improved IP address management of DHCP to Manual changes). See link below.
Firmware
Gerben
People tend to evaluate events in light of their paradigm rather than evaluate their paradigm in light of events.
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
