20 Most Recent HP LaserJet 1022n Printer Questions & Answers
I had the same problem with this printer. I tried cold resets and flashing the firmware on the printer and still came up with an IP of 0.0.0.0 and the printer still set to manual. Here's what worked for me.
When flashing the firmware the first time, I only had the usb connection from the computer to the printer. After a few other attempts, I tried flashing with the usb cable connected AND the network cable connected from the printer to the wall port. After this the configuration page gave me DHCP and a brand new IP Address.
Here is a working link to the firmware for Windows.
So just simply have the network cable connected while flashing the firmware on the printer, hope this helps.
HP LaserJet... | Answered on Jan 05, 2015
Install first the driver of the printer
HP LaserJet... | Answered on Aug 26, 2014
are you connecting through an ethernet connection? there is more information needed.it sounds like you are by the information that it is asking.Need to know what operating system you are running.If this is not in an office environment with more than one person printing to it you would be better off using local usb cable.
HP LaserJet... | Answered on Apr 15, 2014
the hp 1022 is not capable of printing edge to edge for that matter very very VERY few can. the problem is that the printer needs to be able to move the paper through the machine without distorting the printed image and this requires a LEAD EDGE usually about 3-5mm edge to edge down the long side of the paper the printer is able to get quite close to edge at 2-3mm either side but NOT EDGE to EDGE the only real way of accomplishing true edge to edge is to overprint and trim the final page to size.e.g. print on A3 and cut to A4
HP LaserJet... | Answered on Jan 29, 2014
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
HP LaserJet... | Answered on Feb 06, 2013
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
HP LaserJet... | Answered on Dec 27, 2012
  • From Start button and select Control Panel.
  • Select "Hardware and Sound" and choose "Devices and Printers.
  • Right-click on you HP printer you want to check the IP address of and click on "Properties".
  • Click on the "Ports" tab. The first number listed is the IP address of the printer.
HP LaserJet... | Answered on Aug 28, 2012
Try this:
But first print a configuration report.(contain IP address)
Configuration Report
Release GO after LED begins blinking.
Now:
Reset the factory default settings (cold reset)
Turning on the printer while pressing the GO and CANCEL JOB buttons restores the factory default settings.
1 Turn off the printer.
2 Press and hold the GO and CANCEL JOB buttons.
3 Turn the printer on and continue to press and hold the buttons until all three LEDs are blinking.
4 Release the buttons.
HP LaserJet... | Answered on Jul 13, 2011
You need to uninstall the HP solution center and other HP printer software from add/remove programs or program and features, in your control pannel.
Disconnect the printer from the USB, use the disc which came with the printer or download the printer software/ driver from HP.com or click the link below.
Driver download link (after clicking the link select the operating system and click on next as shown in image below)
Install the driver/ software and follow on screen instruction, connect the printer when the software will ask.
Give a test page print.
Note: Uninstall the HP printer softwares before installing it again.
Regards,
Shrey
HP LaserJet... | Answered on May 31, 2011
Go to hp.com, then support and services, in that site you can contact online and ask their specialist.
HP LaserJet... | Answered on May 30, 2011
Make sure you don't have the printer connected until after you install the driver. If you had the printer hooked up to the computer before you installed the driver, uninstall and start over. There should be a prompt during the installation process that tells you when to hook up the printer. If that doesn't work, you may have a driver for a different operating system than what you have on your computer. If you need further assistance, please email me the operating system you are using on your computer.
HP LaserJet... | Answered on Feb 07, 2011
I had exactky the same issue. The problem is not with the front door or the cartridge. I solved this as there was a very small paperjam. If you take out all the paper and shine a torch into the printer you may find a small piece of paper stuck on the sensor that is causing the problem
HP LaserJet... | Answered on Feb 06, 2011
try click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
HP LaserJet... | Answered on Jan 05, 2011
Download the proper driver from hp(http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=439323)
and installit according to your operating systemthats it.
Thanks
please vote for me
HP LaserJet... | Answered on Dec 14, 2010
go to Wireless Printing Center
If you need more help come back.Post / thumbs / testimonial are welcome!
HP LaserJet... | Answered on Nov 12, 2010
HP LaserJet 1022n Printer Logo
61 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laserjet 1022n printing multiple
  • Office Equipment & Supplies
