Get error message INK CARTRIDGE ACCESS DOOR OPEN
SOURCE: Repeated error message
Very Simple, Probably...
Just remove the cartridge and see if the metal spring clip has broken away from the right wall. If it has, inspect the gold colored circuit board at the back of the cartridge bay...there is probably a hole or dent where the clip slammed into it.
If you have these symptoms, go to HP, and go to the chat support window, describe your problem, and they will send you a replacement printer.
It's exactly what I did.
SOURCE: Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
SOURCE: door error message
you may have a broken cartridge lock or door sensor. remove all the toner cartridges. then open and close the door and watch for 4 white hooks that open and close on the right interior of the machine where the cartridges are installed. if three of the 4 open and close with door then the one that doesn't is your broken lock. if all 4 work then you have a broken door sensor. Good luck.
SOURCE: I replaced the color ink cartridge. Now I get a door open message.
Hello
I am Hp employee
visit on this http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00819086&lc=en&cc=us&dlc=en&product=1153485
it will help you
Thanks & Regards
SOURCE: False error empty cartridge
HP C6280 reset:
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow until "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
