Kesalahan 5100
You should keep the cancel button (just on side of color buttons) and then the led screen will show 1 and then press the copy button (black or color). it worked for my printer, hope it works for you
sorry, i missed the word pressed, keep the cancel button pressed
Error E16
Thank You thank you for this wonderful solutions. I've tried it and it worked.
SENDY Rachdy
, I have a solution
1: turn the printer off
2 While pressing down the stop / reset button (denoted by triangle within a cycle), press the power button and hold the stop / reset button until the power indicator lights, continue to hold the power button and release stop / reset button
3: Continue to hold down the power button and press stop / reset button 6 times, alarm indicator turn on and off as you
4: Release all buttons, the printer is now in the service mode
5: tool v1074 download below website and extract the file once downloaded and run the file to open the page of the service tool
http://printertools.blogspot.com.au/2010/12/servicetool-v1074.html
6: to the top of the page find the "clear ink counter" and click on the "Main" button now scroll down the page to find "against ink absorber" to the left and right of the "cons-value "ensuring ink absorber counter box reads" main "and the counter reads" 0 "now click on the knob to the right of the box the counter.
also
7: The printer will now make a little noise and allows you to print a page of paper, you will also get some instructions that appear on the screen of your computer to warn you that the process was completed just click on the request.
8: once this is complete turn off the printer, wait a few seconds and turn it back on and your back in business, at least I was, I hope it works for you too
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
