20 Most Recent Canon PIXMA MP280 Multifunction Printer - Color- 43 Second Photo 4800 Questions & Answers
Error code E61 mp280 canon?
press and hold stop/reset 5 second. :) hope will works by Service printer jepara
11/24/2021 6:30:12 PM • Canon PIXMA... • Answered on Nov 24, 2021
How to fix error 5200
Check out this YouTube video. https://www.youtube.com/watch?v=Pcf-WSW20k8
10/4/2016 1:51:07 PM • Canon PIXMA... • Answered on Oct 04, 2016
How can I remove rear panel to clean out paper drive?
PDF]Canon MP280 series On-screen Manual
content.etilize.com/User-Manual/1017865665.pdf
See Operation Panel. .... Lights or flashes orange when an error occurs, such as paper-out or ink-out. .... You can switch the size of paper loaded in the Rear Tray between A4 and 8.5" .... Remove the original on the Platen Glass after scanning is completed...... For details on the printer driver settings, see Printing Documents.
1/7/2016 11:59:14 PM • Canon PIXMA... • Answered on Jan 07, 2016
How do I remove back panel to clean out jammed paper drive?
It will most likely have screws on the bottom and you will have to remove the whole cabinet. Not just the back.
1/7/2016 10:25:16 PM • Canon PIXMA... • Answered on Jan 07, 2016
5800 canon mp287
cara mengatasi Mp 287 error 5800
5/19/2014 3:28:43 AM • Canon PIXMA... • Answered on May 19, 2014
Canon printer crumbles up on the left side
look for something stuck in roller by pulling up on the front scan glass- you see the rollers- clean with dry clean cloth- don't use paper towel= too dusty once the paper is clear, print and while it pulls one side of paper down first, hold it with your fingers and guide it in- do this 3 times and it will get better until it works on its own be patient and it will work- its a 99 dollar printer after all - good luck all
4/9/2014 5:18:35 AM • Canon PIXMA... • Answered on Apr 09, 2014
Canon pixma MP280 error31
hi, error31 and others can be cleared by holding the reset button down until it sounds like it wants to print- push scan and start should be no error and work fine you have to hear the printer work after reset is pressed or you reset again until it works hold button for ten to fifteen seconds 10-15
4/9/2014 5:06:44 AM • Canon PIXMA... • Answered on Apr 09, 2014
My canon MP280 printer keeps giving me an error number P02. There is nothing stuck in the printer, plus I put in new ink cartridge to see if that made a difference. What else should I try?
I had the same error, did the reset and only got another error, e04. I then removed and carefully cleaned the cartridges and the metal points in the printer that read them. The printer reset itself and worked fine afterwards.
1/11/2013 3:28:06 AM • Canon PIXMA... • Answered on Jan 11, 2013
Canon mp280 printing faded after replacing ink cartridge
Hi there, i have the same problem, did you find a solution?
10/8/2012 7:13:07 AM • Canon PIXMA... • Answered on Oct 08, 2012
I needto download a canon mp280 printer/scanner to a thinkpad laptop
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
10/3/2012 12:07:43 PM • Canon PIXMA... • Answered on Oct 03, 2012
0answers
0answers
My Canon PowerShot SX100IS will not keep the date/time. Every time it is turned off, it asks for the date/time to be set. What is causing this?
There is an internal battery that you cannot replace. IT has to be sent into service.
11/24/2021 6:31:13 PM • Canon Cameras • Answered on Nov 24, 2021
How do i fix e31 on may canon
11/24/2021 6:30:51 PM • Canon Cameras • Answered on Nov 24, 2021
Flash/Auto setting not working on Canon Rebel EOS 2000 35mm camera
remove the film and have it repaired and serviced by Canon. It is worth getting it fixed if you like using film. A number of companies are now making digital backs for cameras.
10/13/2021 10:08:06 PM • Canon Cameras • Answered on Oct 13, 2021
When insert any sd card canon 70d says cannot creat folder
The part where the SD cards are inserted could be dirty and should be cleaned out with qutips and rubbing alcohol or it could also needs replaced as well.
6/1/2021 4:12:45 AM • Canon Cameras • Answered on Jun 01, 2021
Cannon powershot A530 digital camera Camera
Try Formatting the card.
Someone could have locked it accidently.
2/25/2021 9:49:07 AM • Canon Cameras • Answered on Feb 25, 2021
Canon PIXMA MP280 Multifunction Printer - Color- 43 Second Photo 4800 Logo
29 questions posted
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
canon mp280 printing faded after
  • Cameras
