This Error occurs either due to the problem with cartridge sensor or with the ink cartridge. First try replacing the ink Cartridge with a new one. if the error continues replace the sensor. The Error will get fixed.
Visit:
Epson Printer Support Number
If you have any issues with the printer, get the help of Epson Printer Support Team.
If this error came on after you changed the ink ..it is needing a counter s reset ..To do that you have to perform the maintenance mode 02 ..If your printer does not have this mode...you have to download the on line maintenance software ..and reset the counters..for ink and motor..
Also check the excess ink tanks ..(there are 2 of them for most epson ) ..
Many of the Epson printers ink cartridges have a sensor thatallows the printer and the associated software knows when to replace theprinter ink cartridges (even when the cartridges have ink within them) and whenthe printer needs to be cleaned. You mayreceive error messages if that sensor is faulty. In that case you shouldreplace that sensor. Hope this will help you. Good Luck.
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Hello
Is there any other option to make some kind of bypass until i replace the sensor ?
Can i replace it by my self ? if yes, how ?
Thanks
Itzik
Dear Sir
Your solution did not solved the problem. Today printer technician
came to check the printer and he said that the problem is with the ink cartridge. they are not the original one and that the reason for this problem. He installed the original cartridge and the error disappear.He did not change any sensor.
Now the printer work very good.
Itzik
