In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
It is stuck in the defrost mode...
Check out these tips...they can help you figure out what is going wrong with your refrigerator Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Open the freezer door , and press in the light switch . Do you hear the freezer fan come on ? Is there a frost build up inside the freezer , on the rear wall ? Need your model number to help also .
