temperature controls are out. Changed main control board but problem persists. fridge is still...
(More)
temperature controls are out. Changed main control board but problem persists. fridge is still chilling, ice works etc
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water...
(More)
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water seem to be running
carrots, celery in refridg bottom crisper door get soggy?? settins at 55. What can I change to...
(More)
carrots, celery in refridg bottom crisper door get soggy?? settins at 55. What can I change to correct problem?
13 year old GE Profile fridge is not keeping items cold with settings of freezer and fridge set to...
(More)
13 year old GE Profile fridge is not keeping items cold with settings of freezer and fridge set to highest. Could it be the freon. If so, how do you refill the freon?
Why doesn't the express thaw turn off on my GE side by side? This is the second time. The first time...
(More)
Why doesn't the express thaw turn off on my GE side by side? This is the second time. The first time it was because of a bad main controller board. I changed the main controller board, but 2 years later the problem is happening again.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
