Tip & How-To about Refrigerators
Refrigerator not Cooling or Fridge not Cooling
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Refrigerators Logo
Smelled gas and check engine light came on. Periodically have smelled gas over the past 6 months or so. What is cause?
Hi Ed.
this is all i could find at the moment.
Gas Cap Causing Gasoline Smell in Car. I know it may seem obvious, but a loose or missing gas cap can cause a fuel smell in your vehicle. You could even have a faulty gas cap that is leaking fumes. A faulty gas cap can also cause the check engine light to illuminate with a DTC on newer cars.
Gasoline Smell in Car, 5 Common Causes - Simple Car Answers
or go to this link and read up some more.
Smelled gas and check engine light came on Google Search
Nov 04, 2017 | Cars & Trucks
What does Error code 35 on an induction cooktop mean
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
Feb 18, 2015 | Cooktops
problems with cadillac sts
nothing worth reporting
national wildlife refuge
national weather radio
no worries right
i tried but have never heard of it and did a quick search and nothing as well... Post an email to GM, see what those brillant people can come up with... pun intended
Dec 30, 2013 | Cars & Trucks
131,698 people viewed this tip
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
