Amana DRT1802B Top Freezer Refrigerator Logo
Question about Amana DRT1802B Top Freezer Refrigerator
Freezer no working
Posted by rag259 on
Anonymous
  • Amana Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer no working - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
3helpful
2answers
2helpful
Top freezer is getting cooled but bottom freezer is not getting chilled
Check freezer fan behind freezer is working. Check ice formation not abstracting the fan by working. This is the common problem- defrost failure. Check thermostat,timer and freezer heater are working.
Simple way of solution. Unplug fridge for some times and after defrost completely, restart the unit.Keep freezer temp @5 degree.
9helpful
2answers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 • Freezers
1helpful
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Freezer just stopped working
  1. You need to unthaw the freezer, and it should start working.
Sep 11, 2009 • Freezers
1helpful
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
1helpful
2answers
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Top Amana Refrigerators Experts
Steve
David Shaub
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
