Troubleshooting & Support
Hot Topics:
- water leak
- temperature...
- wr55x10942
- water dispenser...
- remove door
- drain pan...
- door handle...
- food freezes
- door hinge
- water line...
- evaporator fan
- defrost
- door stop
- damper
- motherboard
- thermistor
- turbo cool...
- tfx20jr
- tfx27f
- reset refrig...
- ice maker...
- tfx22
- damper door
- profile...
- gss25
- freezer
- water leaking...
- troubleshooting
- ice maker not...
- profile artica
- View All »
Problems & Solutions
MY GE TFX30PRY still cools but doesn't get
Since you say that it still cools, you need to start out with a thorough cleaning of the condenser grill. If it the air flow is...
I Have a GE Profile
Hello, Your pretty much spot on...it does sound like the drain is blocked. This tip i wrote will assist you in clearing that drain....
I have a GE GSS25TSRD
Remove the ice bin and move the metal bar that sticks out the back of it up and down. It should move easily and spring back. If ok look at...
my water dispenser is not
The most likely problem is the water inlet valve P/N: WR57X10032 but you might want to check that the house water valve was not turned off...
I have GE refregrator (side
Hi, You are describing a problem to be either your water valve is stuck open or you may have air in the line creating a siphon. If with...
I have A GE side
There is 2 stats. to run defrost. One is white and is located upper left corner. This is the one that sends into defrost and stops the...
my fridge keeps freezing things
Hello, What the most likely thing causing that is that the air damper that opens/closes to let air into the refrig. section is stuck open...
Ice forms under icemaker and
You need a new ice maker. The seal in the shaft is bad. The icemaker is a throw away no repair parts. Sears parts has them for 125-130...
My side-by-side GE refrigerator, Model
replace the main board located behind the unit behind a silver colored panel at the lower side new board number is a g.e.# wr55x10942
GE side by side freezer
Hi First use a multi-meter to test the compressor. For that you have to unplug the refrigerator and remove the start relay off of the side...
Does GE TFX22ZR side by
Hello, Your refrig is a older model and does not have a built in filter, if it did it would be in the upper right corner of the fresh food...
Freezer problem.....Frozen coils and glowing
That red glow is the defrost heater. Its supposed to do that. It should have defrosted and kicked back into cooling. Here is some extra info...
Model HSS25IFMDWW The freezer
Can you hear the compressor running? Pull the unit out from the wall and see if you can hear it and also look at the evaporator fan to see...
PSG25 side by side
HI, As I am a certified GE technician, I need to ask, has or did the person at your home use a computer on your unit? Reason I ask is...
I have a GE side
if the heater was glowing thats good and you changed the defrost thermo . and thats good .. . the problem is the main board / in the back .....
Unsolved Problems
my GE refrigerator/freezer model mpo. GSS01ETD WW...
the water is turned off and it still freezes and cannot dump the ice. my question i guess is, how do we know if we just...
vent at floor
there's a piece that goes at the floor - can't get it on
psc23sgrc
cooling issues and lights flickering on control panel
My GE refrigerator stops cooling and the freezer...
My refrigerator compressor works fine but then all of a sudden everything is defrosted (meaning food), throughout the...
GE profile Refrigerator/Freezer Model PS123NG -...
GE profile Side by Side Refrigerator/Freezer Model PS123NG(RD BV) The ice maker dispenser external lever causes the...
Upload a manual for GE (PSS26MSRSS) Side by Side Refrigerator
Specifications
TopKey Features
Full Product Name:GE (PSS26MSRSS) Side by Side Refrigerator
Type:Side by Side
Total Volume:25.5 cu. ft. / 722 liter
Fresh Food Volume:16 cu. ft. / 453 liter
Freezer Volume:9.5 cu. ft. / 269 liter
Ice Maker:With Ice Maker
Total Number of Shelves:3
Fresh Food Compartment
Door Opens:Opens to Left and Right
Dimensions
Overall Depth:34.88 in.
Overall Height:69.25 in.
Overall Width:35.75 in.
Warranty
Warranty:1 Year Parts and Labor
Warranty:5 Years Parts and Labor (Sealed System)
What's your problem?
Fix-O-Meter
641,491
641,491 people have viewed this product
- 5,649 people asked about this product.
- 2,520 people found solutions for this product.
- 91 people have added this product.
General Safety...
Pins on the...
How to fix your...
