Tip & How-To about Refrigerators
If you have a refrigerator or a freezer that is not working like it once did then you are looking to get it working again. The reasons why he unit may not be working properly can be many. One of the reasons may be that the refrigeration unit that is the cooling power of the unit is slowly leaking refrigerant.
If the refrigeration unit is leaking very slowly the loss of charge may be so subtle that you will not notice it till the unit basically stops cooling completely. Then all of a sudden you realize that you have a problem. If this is your problem, you will notice that the compressor is running, the circulating fan(s) will be running, and the condenser fan is running. Everything appears to be perfectly normal, but you are not getting the cooling from the unit that you need.
If you have this situation then there is often not that much that you can do. To recharge the unit you will need to find a technician that is certified to handle refrigerants. The system which is charged and sealed at the factory will have to be tapped and the proper refrigerant added to the unit. Even then you still have a system that is leaking and the fix will only be temporary. Sometimes the leak point will be obvious, other times the leak may be very difficult to find. Most of the time, the leak will be next to impossible to find and repair.
Bottom line here is that you will have to make some hard decisions about the repair of a leaking refrigerator or freezer. If you get refrigerant added to your unit it will be a temporary fix. If you can find the leak and it is repairable, you will have a bill for that repair also. That bill may be more then the unit is worth if it is a basic model or an older model. In many cases the purchase of a new unit may be the best option.
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
