SOURCE: Samsung RFG 297 has ice build up under the Cool
• Check if the set temperature on the digital display is too low.
• Try setting the refrigerator to a warmer temperature.
• Is the temperature in the room too low? Set the refrigerator warmer.
• Did you store the food which is juicy in the coldest part of the refrigerator? Try moving those items
to the other shelves in the fridge instead of keeping them in the colder areas or bins.
• Is the air vent blocked? Remove any obstructions so air can circulate freely.
• Allow sufficient space between the stored foods for efficient air circulation.
• Is the freezer drawer closed properly?
There is a ton of information regarding your fridge at the link below, including asking Samsung support questions and getting responses and assistance from their techs:
http://www.samsung.com/us/support/owners/product/RFG297HDBP/XAA#
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
SOURCE: samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Testimonial: "It worked! Thank you so much!"
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
