20 Most Recent Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Questions & Answers
Always the filter warning light operates on its ability.If it came earlier on means that the filter is clogged and needs replacement.
Samsung... | Answered on Jan 03, 2018
Samsung draws are removable, but they are a pain and have to be pulled out, then lift up which allows you to bet the nylon wheel guide to dip under stops, and sometimes takes a little force taking out, and putting back in.
CERACOAT-NANOTECH.com
Samsung... | Answered on Mar 13, 2016
sounds like the fan has picked up some dirt, dust or debri, may need cleaned
Samsung... | Answered on Jan 20, 2016
A good place to view exploded parts diagrams is Sears Parts. See http://www.searspartsdirect.com/samsung-refrigerator-parts/model-RFG297AARSXAA0000/1482/0161000.html. Note that the parts you are looking for could be in the left door diagram or mor likely the cabinet diagram.
Samsung... | Answered on Aug 15, 2015
5E or SE error appears when you have a shorted touchpad and the solution for this is to to put your fingers on the upper right and left sides of the display and the display will restart.
The reason why you are getting this is because when the power is restored there are events where voltages increase for a few seconds (power surge). It is recommended that if you have a power outage you should unplug the power cable of your fridge to avoid damage.
Let me know if this helps.
Samsung... | Answered on Jun 21, 2015
USING THE COLD CONTROL THERMOSTAT AND THE AIR FLOW DAMPER KNOB
Samsung... | Answered on Apr 10, 2015
There are 6 buttons on your display. If you hold the top left one and the middle right one at the same time you turn it into forced defrost. You push the middle right button 2 more times to initiate both coils. The unit should start beeping and can not be shut off unless you unplug it. Check behind the unit in the main board with a amp clamp on the thick wires and see if you're pulling 3 or more amps off the thick orange wire. Or which everyone is labeled heater on the board. If this is working and you're not having a lot of frost build up behind the back panels. Then you have a sealed system issue and I would check the frost pattern on the evaporator to make sure. Unplug it and plug it back in with the freezer back panels pulled down to see how the frost pattern is after 2 hours of running. If it's not completely frosted, check your owners manual because sealed system issues are usually good with samsung and they are covered by manufacturers for X years.
Samsung... | Answered on Feb 02, 2015
yes sounds like a bad fan or seal problem? if ur defrost timer or thermostat was bad u would eventually get severe icing?
Samsung... | Answered on Jan 15, 2015
I'm no expert but because of the problems I've had with this product, I'm getting better. It sounds like you need to replace the Dispenser circuit panel, part #DA97-07821N. It cost about $170.00. You need to remove the old panel. You do this by pulling forward (by hand only) on the display panel from its underside. You will notice a small rectangular hole on the right underside that is large enough for the tip of a wide flat blade screw driver. You can insert it here to assist in pulling the panel forward. Don't insert it too far, only enough to give you some purchase on the panel. Start pulling on this right side and work your way over to the left side being careful not to break the tabs that hold the panel in place. There are two tabs on the right and two tabs on the left and one at the middle top. Once you work out the two tabs on the right, the other tabs will release more easily. Once the panel is removed, it is just "plug & play." Just match up the wire connectors the same way they were on the old panel. When the new panel is connected, insert the panel on to the left tabs first making sure that the wires are tucked into place properly and not "pinched" then work your way over to the right side and pressing the panel on the edges (press around the edges only, don't press the LCD screen) to make sure the panel is seated securely on to the tabs on both sides and the top. turn on the water and plug it it and you should be good.
Samsung... | Answered on Jun 01, 2014
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Samsung... | Answered on May 17, 2014
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
194 questions posted
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
refrigerator cooling off
  • Refrigerators
