Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Power outage when power came back on 33e code came up flashing still on
That sounds like a power glitch. Try pressing and holding the power freeze and power cool buttons at the same time for about 8 to 13 seconds and see if it clears.
If that doesn't do it, let me know and I'll dig up the Fast Track on it.
Posted on Nov 02, 2014
I called Samsung and they said to shut down the fridge for a minute. If that didn't work to call a technician to clear the error code and display. I tried your fix to press the power freeze and power cool buttons at the same time for 8-13 seconds and it worked! Thanks very much!
It worked on mine thanks
It worked cool but iwill it still make ice with the filter light on?
Thank you, it worked
Great answer,
Thanks it worked!!
Thank you!
Thanks! This helped.
VERY WELL, MY PROBLEM WAS SOLVED, THANKS
That worked for me Thanks
That worked for my Samsung rfg293hawp! Thanks so much!
Control panel seems back to normal, so we'll see if the ice maker quits Making ice nonstop...
Si funciona
For Samsung rf260beaesr, it reset pressing power freeze and power cool at same time for at least 10 seconds, didn't count time bit it worked.
Thank you!
thanks
This WORKED: "pressing and holding the power freeze and power cool buttons at the same time for about 8 to 13 seconds"
Thanks.
but not sure if clearing the error code is sufficient or we still need to correct the element, etc.
No. U hold energy saver and lighting
Posted on Jul 25, 2018
I'm a certified Samsung technician. It's just a power failure
Actually this is right. I tried it and it worked. Thank you.
No problem. Glad I could help.
This is correct and has worked for me on 3 separate occasions
Help. Mine still blinks what else could be done.
This refrigerators suck
Has anyone ever had a 33c code
I did today
Just had error code 33C flashing this morning after a power outage. Holding power cool and power freeze reset the control panel back to normal. Thanks.
Thank you!!!!!!!
Removing the error code is one thing; but addressing the real concern behind the problem (to avoid malfunction or overheating) is another thing. any thoughts on how to address it?
Posted on Dec 23, 2021
SOURCE: After power outage, our Samsung
If the power outtage was less than 10 minutes unplug the unit for 20 minutes. Then attempt to restart the unit. If you have a display and nothing happens press power cool and power freeze for 8 seconds then use the up arrow to cycle through until you get to the final test and it should restart. If you still have the problem after doing the above, respond without rating the post and I wll help you. RS2556 Service manual is publication number SAM0097.pdf and can be found here:
http://www.mediafire.com/?mnc7nqc5qdp3ffo Any future response I would provide is sourced from this manual.
Kelly
Posted on Jun 12, 2011
SOURCE: I have a Samsung Refrigerator Model#
On a Samsung Refrigerator model #RF260BEAEBC French Door, press and hold both "Power Freeze" and "Power Cool" buttons simultaneously until chimes sound. This will reset the flashing 13 E code.
Posted on Aug 27, 2012
The next time this happens try pressing the power freeze and power cool buttons together for various time lengths. If this doesn't work, you should call up a commercial refrigeration service for either advice or help fixing it. I do that on occasion when I don't know what to do and everything usually turns out good for me. http://www.pro-staffmechanical.com/servi...
I have the RFG298HDRS. I was able to reset the 33 E code by pressing and holding the Energy Saver (top left) and the Lighting (top right) buttons together for approximately 8-10 seconds.
Thanks Anonymous, it worked for me.
Raylin Sutter, thanks so much. It worked!!! Hurray!!
MSIhappily it worked for me
It worked! Thanks a bunch!!
How about a 33 c, tried to reset seems not to work
WORKS! - pressing and holding the Energy Saver (top left) and the Lighting (top right) buttons together for approximately 8-10 seconds.
Did not work for me. Any other ideas
