Samsung RS265TDRS Side by Side Refrigerator Logo
Anonymous Posted on Feb 26, 2012
Error code 22E on Samsung RS256TDRS refrigerator
I am getting error message 22 E when self-diagnostics is run. The fridge side is not cooling properly and the temperature is around 55-60'F when it should be at 36'F. The fan was making a lot of noise a few days ago but after turning the unit off for a while and turning it back on the noise stopped. I figured ice must be forming around it on the evaporator coils. Yesterday morning there was a puddle of water underneath and the fridge was warm. Freezer works fine though. I think I can still hear the fan on this side but it is barely turning. The freezer fan seems to be working fine. The fridge temp reads 36'F now but is nowhere near that and I get error message 22 E. What is the real problem here and best way to fix it....thank you
  • 4 more comments
  • Anonymous Jul 27, 2012
    i literally have same exact issue
    even temps are same already tried defrosting & putting in new mother board & evaporator fan (per tech advice) still not working & now freezer warm
    did you ever solve problem ?
  • ronald_ortiz Apr 08, 2015
    Soooo, I'm guessing this was not resolved?
  • John Gross
    John Gross Jul 03, 2017
    I was able to fix this exact code (22E). After our doors got left open overnight, and closed the next morning, we noticed it wasn't getting colder. Did an initial reset of 30 minutes and boom, up came the code. We pulled everything out of the fridge - ice maker, drawers, all stuff - and left it doors open, unplugged and with large fan blowing at it. Waited about 12 hours and plugged back in. Reset just fine.
  • Patricia Michalik
    Patricia Michalik Jul 08, 2018
    Can someone help me with error codes PC and Ch?
Levaughn Sellers
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Oct 23, 2019
Levaughn Sellers
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
28035
Points
These answers work guys and get used to coming to the forums every few monyhs. Never buy a Samsung again I've had to service mine some form or another at least 8 times in the past two years I did just read about paying close attention to the Styrofoam around the fan drain and possibly trimming I hope that makes it last longer than two months
Betty Bloom
Level 2:
New Friend:
  • Expert 20 Answers
  • Posted on Jun 11, 2018
Betty Bloom
Expert
Level 2:
New Friend:
Answers
20
Questions
0
Helped
36748
Points
113
Your problem seems serious, but it can be solved without the help of a service center. You can perform self-diagnosis. If you see the error codes on the display of your refrigerator - solve the problem will be even easier. It is enough to find information about that error code on the Internet, and in the user's manual. Samsung refrigerator error code 22e
Jorgie the appliance guy
Level 3:
Top Expert:
  • Samsung Master 5,639 Answers
  • Posted on Apr 09, 2015
Samsung Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1527473
Points
32630
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
5 Related Answers
A
Anonymous
  • Posted on Mar 26, 2008
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
I have RS2555 in same problem.my warranty is expired and Samsung hooked me up to an technician who asked for 300.00 for labor plus parts and tax, what a rip off!!I I called my Canadian friend who's a technician and I was told to POWER OFF the RS2555 for 24 hrs.both doors MUST open and take out all drawers,he said ,it is 90% the ICE blocked the cool airflowing,so if ICE melted,all will return to normal.
It works after I did what he said.share this and hope can help some one with same problem!
Anonymous
  • Posted on Sep 21, 2007
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
DrLindquist
  • 5 Answers
  • Posted on Sep 20, 2008
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Anonymous
  • 7 Answers
  • Posted on Jul 11, 2010
SOURCE: We have a samsung side by side fridge freezer
Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
Anonymous
  • 150 Answers
  • Posted on May 08, 2008
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
1helpful
Samsung fridge cooling but freezer is at 50
There could be ice that has build up on the evaporator coils.or the evaporator coils. needs to be replaced.
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
What does error code 22 e mean?
It's a refrigerator fan error. Click on link then click onto the 22E Error=> Error Codes Messages Blinking
Appliance 911 Sea Breeze
Fridge will not get cold. Someone told me I need to buy a sensor for the fan. Does any one know how to fix this problem
Check, before you do anything else, that somebody has not turned the cooling functiondown.
There should be a rotating switch near where the indicator light on the front is. It might be under a cover of some kind/
Please check, then add this detail and resubmit
2answers
What is a 22 e error code for a samsung fridge
I copied this suggestion from another web site. The 22e error is apparently a blockage of ice. Hope this helps.....
7helpful
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
2answers
Fridge does not start gives error ds
If you like I can help you locate the problem. The error code may be in the service manual but Im not sure about if the manual will tell you how to run self diagnostics if the mother board or the digital low volatage is affected. I enjoy working on the difficult ones if you would like my assistance, Sea Breeze
3answers
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
