I have a Samsung Refrigerator that had a new compressor installed. It cooled for a while and then stopped cooling again. I can hear the compressor running. I suspect the compressor was incorrectly installed or the solder joints were poorly welded. I could see corrosion around the copper near the compressor.
Your PTC relay is bad. Get back with me and can walk you through the replacing it.
SOURCE: Suddenly stopped cooling. Fan runs compressor doesn't.
Hi, If fans are running, most likely relay and/or capacitor. Do you here the compressor try to click on at all?
SOURCE: Refrigerator not cooling, do not hear compressor
clicking sound is motor protector cuting out compressor drawing to much current replace compressor.
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
SOURCE: Traulsen GHT2-32 NUT Refrigerator won't
iced up coils generaly would be loss of ref in system . it may not have been charged properly . and the system may have a restricion in it . causing the same problem .. if its older unit it may not repair well . **** ..
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
