my samsung fridge freezer has just started tripping the mains supply every time i switch it on ,i...
(More)
my samsung fridge freezer has just started tripping the mains supply every time i switch it on ,i have changed sockets,turned everything else off ,so i know it can only be the fridge. could you help me please
The fan that blows air from the freezer to the fridge is making a lot of noise. The fan and noise...
(More)
The fan that blows air from the freezer to the fridge is making a lot of noise. The fan and noise stop when the frezzer is open, but not when the fridge is open. The unit is only a year old but this does not seem to be covered under warranty - of course. How do I get to it and what might the problem be?
Samsung RS2556SH - when power was restored following an outage, the temperature control panel no...
(More)
Samsung RS2556SH - when power was restored following an outage, the temperature control panel no longer worked. No power for any functions including temperature or ice maker. The only light on the panel is a flashing green dash above one of the temperature digits.
not cooling, under the 3rd drawer in the regrigerator compartment it is frozen. It was working then...
(More)
not cooling, under the 3rd drawer in the regrigerator compartment it is frozen. It was working then all of a sudden it quit. The panel on the outside of the freezer shows erratic information or none at all, then it will start kinda working and by that I mean it will cool a little. The freezer portion doesnt freeze but is cooler than the refrigerator. Sometimes if I unplug it and plug back in it helps. We bought it used and can't afford to have it fixed, please any help would be appreciated we have two little children in the household. Thanks
Samsung Refrigerator Model # RS2577SL - the automatic ice maker will not release the cubes and water...
(More)
Samsung Refrigerator Model # RS2577SL - the automatic ice maker will not release the cubes and water continues to empty on top of the already made cubes causing the water to spill out of the freezer
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
