My freezer is no longer making ice, but the lever goes up & down like it's making ice with no problem. The water line still works fine, just can't get it to make any ice.
SOURCE: ice maker not making ice
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this. Let's solve it before you rate it.
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
SOURCE: Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Replace the valve.
You can get required
parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks.
Helpmech.
here are some things to check for, please be very careful and only to this if you disconnect the power supply.
1 Inspect the shut off arm located on the side of the ice maker. This arm should move up and down with a slight resistance when pushing upward. Make sure that this lever is not frozen to the side of the ice maker preventing it from dispensing ice. In addition, if the arm move loosely up and down, then it is broken and must be replaced.
good luck
Iain
