I have a JSD2789GES Jenn-air and the freezer is icing up. There is no abstraction to the the air...
(More)
I have a JSD2789GES Jenn-air and the freezer is icing up. There is no abstraction to the the air channels.
I have a Jenn-Air JSD2789GES side by side that is not cooling on the refrigerator side. The average...
(More)
I have a Jenn-Air JSD2789GES side by side that is not cooling on the refrigerator side. The average temp is about 52 degrees. I have done some basic research and I'm finding that there might be something wrong w/ the circuit board controlling the defrost. I have cleaned everything in the rear and was wondering if I need to defrost the whole unit? Thanks.
I have had a puddle of water periodically on the floor, but do not know if it is from the freezer or...
(More)
I have had a puddle of water periodically on the floor, but do not know if it is from the freezer or the refrigerator side. The freezer has a build up of ice on the back wall which I am defrosting now, but the refrigerator side is now an expensive pantry. It keeps foods cooler than leaving them outside the unit, but definitely are not cold.
The freezer side, as mentioned above, keeps building up ice at the back wall, but unless food items are touching that icy area they are just cold, not frozen.
the freezer on a side by side registers a higher temperature on the led than the actual temperature...
(More)
the freezer on a side by side registers a higher temperature on the led than the actual temperature and it is not making ice consitently
Jenn-Air JSD2789GE Side by Side Refrugerator stop working. I woke up to water on the floor. All the...
(More)
Jenn-Air JSD2789GE Side by Side Refrugerator stop working. I woke up to water on the floor. All the air in air maker was melted and floor was defrosting. Only the fan was blowing. There is no cold air. The compressor is not running! Can someone please help diagonoise.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
